Is the existing 20 gb for $75 plan going to work with 5G when it rolls out?
Dwto
I see that Rogers 20 gb for $75 plan works with 5g, want to make sure the Telus plan will too.
No reason why it wouldn’t. All plans automatically made use of 4G when it began.
1 REPLY 1
