July
July
@Kief wrote:
I can also connect to it using my public ip
What do you mean by this? Are you inside or outside your network when you do this?
July
July
That's not a valid test of access through your public IP then. It's just doing a loopback inside the router. I didn't think the T3200M could do that.
July
I've managed to get it work, but its werid. I'm currently connected to my T3200M wirelessly, using a port checker I can verify the minecraft server is running, however, im aslo connected via eithernet to my router (which is the child of the T3200M). When I disconnect from my T3200M wirelessly, the port closes. Super weird.
July
How are using the port checker? Is it a web site or software/app on your device?
July
Its a website.
To clarify:
When PC connected to: Modem AND router; port is open
When PC connected to: Router; port is closed
July - last edited July
Is your minecraft server running on the same PC you are testing from? That would explain the behavior if your port forwarding on the Asus router is not set up correctly.
July
July
@Kief wrote:
I have followed all instructions. DCHP and Port forwarding has been set.
Set to what?
Did you port forward on both routers?
You have not replied to whether you are running the Minecraft server on the pc that you are testing from.
July
I am running from the PC I have been testing on. Doesn't matter because I have another server and a friend to test off my network.
DCHP has been set to my own local ip on my router, port has been set to TCP and the default minecraft port.
Cheers
July
@Kief wrote:I am running from the PC I have been testing on. Doesn't matter because I have another server and a friend to test off my network.
It matters because it explains why it works when you connect that PC to the T3200M.
@Kief wrote:DCHP has been set to my own local ip on my router, port has been set to TCP and the default minecraft port.
Assign your Asus router to a fixed (DHCP reserved) IP address on the T3200M
Assign your PC server to a fixed (DHCP reserved) IP address on the Asus router
Port forward like this:
T3200M --- [port forwarded to Asus router IP] ---> Asus Router --- [port forwarded to PC server IP] ---> PC server
I have the same routers and the above is how I set up my security camera server which has been working for many years.
July
I cant find my routers ip in the T3200M. It says there are only 4 clients, non of which when I visit come up with my routers web panel
July
If you have port bridging enabled on the T3200M you won't see any device connected to that port.
July
As someone who has port forwarded with minecraft server on Telus internet, it is a pain. Your problem appears to not be using the T3200M modem/router for port forwarding. I also have an extra router for myself and I ran into this issue many times. Perhaps you could solve it by enabling router bridging within the admin panel settings, I'm not too sure if it would work since I never tried it with Telus bridging system, however, then the T3200M modem/router will be unusable in the sense of using it as a router.
Perhaps you could forward the port from one router to the other router, I'm however unsure if this is possible with Telus limited tools since they like to restrict our accessibility.
July
Yeah, that's what I have tried too. Port forwarding my own router, turning on bridging. How did you you fix ti?
Go to the Asus router page that shows the MAC address for the external (WAN) port.
Go to the DHCP Reservation page on the T3200M and look for that MAC address in the drop down in step 1. The currently assigned IP should now be populated for step 2. Apply the change.
Follow a similar process on your Asus router to assign a reserved IP for your PC.
Then set up the port forwards on each router to the respective IP address.
July
Ah, I missed part in the original post about using bridged mode. I recall seeing posts about issues port forwarding in that mode. I don't use bridge mode so I can't say if port forwarding works or not.
What WAN IP do you see from the Asus when you use bridging? Is that the IP you are testing?
July
It starts with 64.. I wans't sure. Thats not local
So if your Asus router is getting an external IP then all you need is the port forward set up to the reserved IP of the PC when it is connect to the Asus router.
Another thing to check is whether the WAN IP shown on the Asus is the same as the IP shown from the port checking web site you use to see if you are behind carrier grade NAT.
