Kief
2 years agoOrganizer
Port Forwarding - Port not opened
Hi, I'm trying to a host Minecraft server with my ASUS router behind the T3200M modem (provided by Telus) Here's what it looks like: T3200M -> ASUS Zen Wifi -> PC All of these are wired. When I...
2 years agoHero
Is your minecraft server running on the same PC you are testing from? That would explain the behavior if your port forwarding on the Asus router is not set up correctly.
- Kief2 years agoOrganizerI have followed all instructions. DCHP and Port forwarding has been set.
- xray2 years agoHero
Kief wrote:
I have followed all instructions. DCHP and Port forwarding has been set.Set to what?
Did you port forward on both routers?
You have not replied to whether you are running the Minecraft server on the pc that you are testing from.
I am running from the PC I have been testing on. Doesn't matter because I have another server and a friend to test off my network.
DCHP has been set to my own local ip on my router, port has been set to TCP and the default minecraft port.
Cheers
