Kief
2 years agoOrganizer
Port Forwarding - Port not opened
Hi, I'm trying to a host Minecraft server with my ASUS router behind the T3200M modem (provided by Telus) Here's what it looks like: T3200M -> ASUS Zen Wifi -> PC All of these are wired. When I...
2 years agoHero
So if your Asus router is getting an external IP then all you need is the port forward set up to the reserved IP of the PC when it is connect to the Asus router.
Another thing to check is whether the WAN IP shown on the Asus is the same as the IP shown from the port checking web site you use to see if you are behind carrier grade NAT.
