Kief
2 years agoOrganizer
Port Forwarding - Port not opened
Hi, I'm trying to a host Minecraft server with my ASUS router behind the T3200M modem (provided by Telus) Here's what it looks like: T3200M -> ASUS Zen Wifi -> PC All of these are wired. When I...
Kief
I have followed all instructions. DCHP and Port forwarding has been set.
2 years agoHero
Set to what?
Did you port forward on both routers?
You have not replied to whether you are running the Minecraft server on the pc that you are testing from.
- Kief2 years agoOrganizer
I am running from the PC I have been testing on. Doesn't matter because I have another server and a friend to test off my network.
DCHP has been set to my own local ip on my router, port has been set to TCP and the default minecraft port.
Cheers
- xray2 years agoHero
Kief wrote:I am running from the PC I have been testing on. Doesn't matter because I have another server and a friend to test off my network.
It matters because it explains why it works when you connect that PC to the T3200M.
Kief wrote:DCHP has been set to my own local ip on my router, port has been set to TCP and the default minecraft port.
Assign your Asus router to a fixed (DHCP reserved) IP address on the T3200M
Assign your PC server to a fixed (DHCP reserved) IP address on the Asus router
Port forward like this:
T3200M --- [port forwarded to Asus router IP] ---> Asus Router --- [port forwarded to PC server IP] ---> PC serverI have the same routers and the above is how I set up my security camera server which has been working for many years.
I cant find my routers ip in the T3200M. It says there are only 4 clients, non of which when I visit come up with my routers web panel
