Vcam
3 years agoNeighbour
Home phone call control error message
Getting error message "something went wrong try again later" for past 3 days. Called support but the tech seemed to be clueless. It used to work and is included in my plan. Any suggestions?
- CraftyCanadianNeighbour
Also seeing exact same message when I try to activate call control. Technical help is a joke they have no idea and just keep bouncing me around.
- dru
Community Manager
How long has this been going on for? Can you try the few different ways you can modify Call Control outline here to see if any one method works better?
- VcamNeighbourOn my tablet - telus.com/mytelus and on my cellphone the Telus appUnder services,home phone,call controlError message "!Looks like something went wrong. Please try again later." Has been this way since at least December 11,2023.Telus support on December 11th did some kind of a reset because my phone was not working and since then call control has not worked and I cannot access call control function on either device.Appreciate it you can fix it, hare those robo calls.M Vicki Campbell
