mtwohig's avatar
mtwohig
8 months ago
Power adapter issue on Telus TV Box
I have a couple of Telus TV Android boxes. One of them stopped working, just won't turn on. After googling I found the issue was likely the power cable. I tested it by swapping it for the power adapter on our other box and it works.
Saw a reddit post that said you can arrange to have a new power adapter mailed out. Looking for help, please let me know.
  • Barrick's avatar
    Barrick
    Friendly Neighbour
    My power adapter just failed on my wireless 4k optik digital box. Can anyone recommend a replacement unit on Amazon that would be compatible?
    • Rocky3's avatar
      Rocky3
      Guardian
      Please read THIS whole thread for the answer which I have posted. I am not going to re type.
  • In the past week my digital box Telus TV 21T has been problematic after 10 months of use. They are sending me a whole new box. Any alternative adapters one could stock up on?
  • TELUS_Support's avatar
    Sorry to hear about the trouble with your TELUS TV box's power adapter, Mtwohig. It's great that you were able to identify the issue by testing with another adapter. To look into replacement options, please send us a private message with your account details, and we'll be happy to assist you further.
        We can definitely look into that for you. We'll send you a private message to discuss further.
  • geekette2025's avatar
    geekette2025
    Friendly Neighbour
    That should definately not happen for sure mtwohig​ you should send the telus tv box back through one of the postal outlets and then ask for a new one.
    • Rocky3's avatar
      Rocky3
      Guardian
      Nothing wrong with the box, it is the power supply. If you put a multimeter on it it will read 11.5~ and not 12V and does not produce enough amps.
      Yes have Telus send you another power cord and/or order one from amazon for $15. The amazon one has not failed since January when I reported this.
      Let us know which one arrives first.
      • Timmah1's avatar
        Timmah1
        Organizer
        Can you share the amazon one you found to work?
        I have 3 of the boxes and the first one now has this issue. I suspect the other 2 will also develop this issue over time.
