mtwohig
8 months agoNeighbour
Power adapter issue on Telus TV Box
I have a couple of Telus TV Android boxes. One of them stopped working, just won't turn on. After googling I found the issue was likely the power cable. I tested it by swapping it for the power ada...
geekette2025
8 months agoFriendly Neighbour
That should definately not happen for sure mtwohig you should send the telus tv box back through one of the postal outlets and then ask for a new one.
- Rocky38 months agoGuardian
Nothing wrong with the box, it is the power supply. If you put a multimeter on it it will read 11.5~ and not 12V and does not produce enough amps.
Yes have Telus send you another power cord and/or order one from amazon for $15. The amazon one has not failed since January when I reported this.
Let us know which one arrives first.
- Timmah17 months agoOrganizer
Can you share the amazon one you found to work?
I have 3 of the boxes and the first one now has this issue. I suspect the other 2 will also develop this issue over time.
- TELUS_Support7 months ago
We've replied to your private message, thanks.
