4 weeks ago
I have easy roam on my plan. I don’t want to pay 16$ a day but want to have my phone on incase there is an emergency back home so someone can get ahold of me. If I turn data off and leave my cell service on will I still get charged?
4 weeks ago
If you leave you cell service active you're likely to be charged roaming cost. When I travel to the States I put my Apple iPhone in airplane mode but leave my Wifi activated. I then will communicate to family and friends using Wifi from the hotel via social media messenger apps. There are travel sim cards you can purchase for you phone however you will be assigned a different phone number. There are usually no guarantee the travel sim cards work seamlessly so make sure you do your research before you take this route of purchase. Alternatively if you want the easiest seamless operation of your cell coverage pay the 16$ and select your days of usage.
3 weeks ago
Hi there! With Easy Roam, you’re only charged the daily rate if you use your device while travelling, such as making or receiving a call, sending a text, or using data. If you turn off mobile data and do not make or answer calls or send texts, you won’t be charged. However, if you receive a call and answer it, or if your phone uses data in the background (like updates or app notifications), the daily charge will apply.
3 weeks ago
You are correct. I have done this numerous times in Mexico and other places. Just turn off cellular data and roaming and you can keep your phone turned on, to receive texts and view any incoming phone calls that you receive. You will only activate Easy Roam if you send a text or answer or make a phone call. I have never received a charge this way over a good many trips. Also, get WhatsApp for texting. You can text anyone on the app and you can search people as well. It looks like regular texting but is 100% free and works over WiFi.
