February
February
Contact tech support directly. 1-888-811-2323.
February
What do you mean wifi signal is blue but the internet is red?
You can try to factory reset it then reboot it.
February
A red internet light means it has no connection to Telus. As long as the cables are all still properly connected, that typically involves tech support and/or a repair tech.
