- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-14-2022 11:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
04-15-2022 11:55 AM
Our doors, and lock get notification, but motion sensors don’t. Always been that way. I’ll see what I can learn.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
04-16-2022 03:22 PM
@Buckbuck
On the panel, there is a “Edit Sensors” once you enter the administration area by dragging down on the marker at the top of the screen. From the list of sensors, are the motion sensors, and in those you can set the chime or voice options, including “none.”
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
04-15-2022 11:55 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
04-16-2022 03:22 PM
@Buckbuck
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Accept as Solution
05-06-2022 09:43 AM - edited 05-06-2022 09:44 AM
Unfortunately, on the Neo panels, the end user can only turn chimes on and off on a system wide level by pressing and holding the "Chime" button. To turn it off on individual zones, it has to be done in system programming and requires the installer level access code.
Motion detectors should be programmed as an interior device so by default the chime is disabled. If they are programmed as delay zones, then the chime is enabled. A technician will need to see how it is programmed and either change the zone definition or the zone attributes.
