a month ago
a month ago
Hopefully you were left with a user guide from the installation. You should be able to access the programming mode of the panel and navigate to the sensor management section. From there, there should be an option to delete or remove a sensor. It'll ask for the specific sensor and/or sensor panel number.
Have you been able to get this done or speak with our team since posting?
a month ago
a month ago
Give our SmartHome team a call at their direct number 1-855-255-8828 and they can look into it with you.
