- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-18-2024 08:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
03-19-2024 12:34 PM
Apologies for that. There are of course some first level troubleshooting things to check (of which you most likely have done some...)
- Ensure the call volume in your doorbell settings is set to maximum (you mentioned this one)
- Ensure the Wi-Fi connectivity of the doorbell is strong (use the 2.4GHz band and/or move the router closer to the doorbell for a better connection).
- Make sure you are holding the "Hold to Talk / Push to Talk / Talk / Mute" button the entire time you are speaking into your smartphone if applicable to the situation.
- Check if the microphone settings are disabled on the device. Uninstall and reinstall the SmartHome app and allow access to the microphone when prompted.
- Reboot the affected camera.
If none of these are doing the trick, equipment replacement or further troubleshooting is most likely needed. You can reach the SmartHome team directly at 1-855-255-8828.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
03-19-2024 12:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Accept as Solution
May
