- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
November
I would like to establish a connection between the modem in the basement and an upstairs room wired with Coax.
Currently, the single Coaxial connector on the modem is already in use: connected to another Coax cable (then MoCA 2.0 to modem) to the main floor; so I cannot use that.
Would the following setup work? Connect first MoCA to ethernet socket on modem in basement (ethernet in & Coax out) and connect second MoCA (Coax in & ethernet out) upstairs. Also, would I need to enter any settings or would this work plug & play style?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
November
Yes, either way you need an adapter on the other end.
Signal strength is not an issue as far as the splitter if you don't buy a cheap no-name splitter. Another factor may be the quality of coax cable and termination in the walls.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
November
MoCA should support multiple adapters in a single network. This is assuming the coax lines are all connected together still. If they are not, you'd need a new pair of adapters if the coax is a direct line from where the modem is to the upper floor. That will get expensive. A high powered wifi access point on the main floor may be a cheaper option.
If you find a post useful, please give the author a "Kudo" or mark as an accepted solution if it solves your trouble. 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
November
Just buy a coax splitter that supports MoCA and split the connection from the router to your devices.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
November
If I used a Coax splitter, I would still need one MoCA upstairs to convert to Ethernet, right?
Also, wondering what effect that splitting would have on the signal strength to each device...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
November
