Port Forward on Telus Wifi HUB
Avalon2099
Hi guys, I am a recent convert to Telus Pure Fiber and I was wondering how to accomplish setting up a port forward as I like to play with Open NAT type on the games I play, I seem to be stuck behind a Moderate NAT, even though ive set my Netduma R2 Router to open the correct ports.
Is there a place I can log in to the Wifi Hub like the Shaw Router/internet interface where I used to be able to open the ports via that UI?
Dimo-X
Moderator
Moderator
Hi Avalon, there a few threads relating to this on the neighbourhood. You can probably find more by searching for "port forwarding".
https://bit.ly/3xwdAQR
https://bit.ly/3rcP6rI
https://bit.ly/2Y9XbEK
Cheers 🙂
1 REPLY 1
Dimo-X
Moderator
Moderator
Cheers 🙂
