Is Pi-hole possible with Telus Boost Wifi 6?
JStars
Organizer
There have not been posts that I could find since 2020 on this issue. I just want to confirm before I buy a new router that it isn't possible to get the Telus Boost Wifi 6 (the cylindrical white thing) to use another device on the LAN as a DNS server? This other device would be a Raspberry Pi running Pi-hole.
I have gone into the Boost web admin settings and I see that the DNS is listed as "192.168.1.254" which is the LAN address for the ONT. There doesn't seem to be an option to change this in the web interface.
4 REPLIES 4
The Boost Wifi 6 is merely a wireless access point, not the router. It pulls IPs for devices directly from whatever router Telus has installed. You'd need to change DNS on the main router/ONT.
If you find a post useful, please give the author a "Kudo" or mark as an accepted solution if it solves your trouble. 🙂
I will create a fresh Pi-hole installation and try entering its IP address into the DNS address in the ONT (also referred to as the Network Access Hub) and report back.
So I have changed the DNS entry on the ONT/NAH to the Pi-hole's IP Address: 192.168.1.150
Devices seem to pick up this address as their automatically assigned DNS server address. However, ads are still not being blocked network wide. However when I manually assign "192.168.1.150" as the DNS server on each device then ads are blocked. This suggests that there is a DNS leak somewhere in the ONT/NAH. Is there anywhere else in the ONT/NAH settings that I must ensure that the DNS is changed?
I have gotten Pi-Hole to work consistently now. To do so I had to do the following:
  • Disable DHCP on the ONT/NAH
  • Enable DHCP on the Pi-hole (making it the LAN DCHP server)
  • Add the local address of the Pi-hole as the DNS server on the ONT/NAH in "Local Network"
  • Disable IPv6 on the ONT/NAH in "Internet Access"
Given that disabling IPv6 did the trick, I am assuming that was where the DNS leaks were coming from. I don't know what the implication of disabling IPv6 on my network is, but ad blocking seems to be working well.
Type a product name
