How to Replace Telus Boost with 3rd Party Mesh System - With Telus Fiber 150 (Optic)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-02-2020 03:36 PM
Hey all,
I have Telus Optic FIbre Service with both TV/Internet and I'm currently using the Arcadyan Modem and 2 Telus Boosters to create a Mesh Network. I've been having issues though with system reliability, with slow speeds and devices regularly getting dropped.
I'm planning to buy an Eero Mesh (3 node) setup from a friend and install that.
I guess I'm a bit confused though with how to set it up....
My ONT is in my (detached) garage, then routed via Ethernet cable to the current Router in my basement.
Do I need to keep the Arcadyan router and then hook up the Eero router in series with it, turning off the signal from the Arcadyan Router; or can I disconnect the Arcadyan router altogether and plug the EEro router into the ethernet cable coming from the ONT? (I assume not - I assume my Optic TV boxes need the signal from the Telus router?)
ANy advice is appreciated...obviously this isn't my wheelhouse, as you can probably tell 😛
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2020 07:46 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2020 07:48 AM
