jujubehead
5 years agoNeighbour
Weird problem with parental controls disappearing on T3200M
I'm trying to use the parental controls on the T3200M. Looking in the "Advanced Settings" screen, the menu item on the left for parental controls was not there at all. The admin home screen s...
- 5 years ago
Hi there,
I have an update. Working with a couple resources from TELUS support management and development they have confirmed that the TELUS My Wi-Fi app is the supported replacement for the parental controls in the T3200M modem. This change is effective with the last firmware upgrade to the modem, version 31.164L.22.
Reverting to firmware 31.164L.18 or lower, through a factory reset of the modem, will restore the original Blocking/Filtering section with parental controls in the T3200M modem, however the workaround would be temporary as the modem will continue to pickup the latest firmware from TELUS and perform an automatic update. The new firmware is more secure than .18 so this is likely not a recommended solution.
The parental controls in the TELUS My Wi-Fi app have some know limitations compared to the original T3200M-based controls:
- Scheduling: Some devices cannot be paused or included in the child profiles (Ex TELUS Optik STB). TELUS Optik PVRs work fine.
- Filtering/Blocking: There is no definable web or protocol filtering, other than the generic option to filter out Adult content based on age ratings.
To filter specific apps, such as YouTube, TikTok or Pokemon. If you own an Apple device with Family Sharing setup, there is a relatively new setting called Screen Time that has proven to be an absolute life savior for our family's balancing of digital time: https://support.apple.com/en-ca/HT208982
There are similar options provided by Microsoft for Windows and Android (https://support.google.com/families/answer/7103340?hl=en), but I am less familiar with them and do not want to stray to far off thread here.
Hope this helps.
worldtel
5 years agoOrganizer
I have also lost the parental controls. I have actually lost all the Blocking/Filtering section seen here circled in yellow:
I am currently on the phone holding in the 1 hour support queue to see why this is happening and if it can be resolved.
Once thing I noticed under my Upgrade History was that my T3200M's firmware was upgraded in September from 31.164L.18 to 22. This could be the culprit:
| 09/23/2020 | 12:43 AM | ACS | Complete | 31.164L.22 |
I will keep you posted.
BrianF
4 years agoNeighbour
Same Problem. The entire Blocking/Filtering section at the top of Advanced Setup is simply gone on new firmware.
These features are extremely important!
- BrianF4 years agoNeighbour
More info (can't edit previous post):
This problem exists on a Windstream T3200 (no M) using firmware WST3K-31.165L.38
