RonD
2 years agoNeighbour
Volume Control
Using an Optik TV-21T box with a Monitor type TV, so no tuner and no internal speakers, HDMI cable hook up
Monitor has optical audio out but its fixed not variable same as the Telus box's optical out
Monitor has analog audio out but no sound transfer from digital HDMI signal
Monitor's remote has no volume control buttons in any case
I am using an HDMI audio extractor hooked to an amplifier with no IR volume control for speakers
Telus remote works OK for volume up/down until I program it for TV on/off, then I lose variable volume control
Is there a way to set Telus TV box/remote as default audio control while keeping TV on/off function
Hi RonD , this is outside of our support, but perhaps you can try the following to see if it will work:
1. Hold Input and Left on the DPad for 3 Seconds
2. LED on remote should be solid green
3. Press OK
4. LED on remote should blink white, green, white, green
That command locks the volume control to the STB
- RonDNeighbour
No, I haven't got thru to tech support yet
From other posts in this forum, and my experience with my other regular TVs, as soon as you program the remote for a TV brand/model the remote's volume buttons default to that TV brands IR commands, so no longer sends Telus box volume up/down commands
I doubt many people would ever run into this issue, most would be using IR controlled Home Theater Amplifier with a Monitor type TV, and that can be programmed
But didn't see an Optik code to reset volume back to Optik box while leaving the TV on/off as is
- Optik-Kate
TELUS Team Member
3. Press OK
- TELUS_Support
Hi RonD to my understanding your remote should work for both. Have you contacted our technical support team for assistance?
