amam's profile
Organizer
20 Messages
Closed
I have parental controls set up on my modem. My daughter has figured out a work around. She resets the modem to default then unplugs the printer ethernet cable and plugs it into her laptop. She gets full internet access and the rest of us are knocked out. I have her laptop blocked (wireless & hard wired) but the reset deletes everything. Are there any other options other than physically moving the modem? (It would cost me to relocate to another part of the house.)
When she did this last night, the parental controls in the Telus GUI had even disappeared!!
Accepted Solution
Rockstar
407 Messages
Or you could get something similar to a Meraki, which although intended for business, is cloud managed and only works when it connects to the cloud (and it downloads the settings).  If you hit reset on a Meraki, it will just get the settings that were in previously....
Rockstar
317 Messages
The other option would be to downgrade her computer account to a standard user and yourself as an administrator, then limit the settings she can control. Depending on if she's using a Mac or PC, there are different types of parental controls available.
Windows 10: https://www.howtogeek.com/666985/how-to-use-parental-controls-in-windows-10/
Mac: https://support.apple.com/en-ca/HT210387
Organizer
20 Messages
Thank you for your reply. My kids do NOT have admin rights. That would not be good! I'll have to test out microsoft family again but they found loopholes in that before. Same with qustodio and k9. Thanks for the links.
Organizer
20 Messages
I'm afraid you're right. I just may have to pay for modem to be relocated. Was hoping for other options first.
I read about disabling the ethernet connection on her laptop so I tried it but it did nothing.
I've heard of meraki but I'm not that tech savvy and my friend who has it has issues with it competing with her wifi.
Yes, I know other parents with similar issues.
Thank you!
Advisor
2.7K Messages
Both good suggestions above. However there is only so much technology can do to address this situation. There is a behavoral factor here that is out of reach to technology.
If you can't move the router to a secure location then perhaps try to physically secure the router at the current location. Maybe something like this would work:
https://www.amazon.ca/Lockabox-Compact-Hygienic-Lockable-Medicines/dp/B01KVKMGBE/ref=sr_1_42
Drill holes for ventilation and cables. Depending on which router you have you may be able to drill holes for the antenns as well but polycarbonate is fairly transparent to WiFi so it may not be needed.
Organizer
20 Messages
I agree. I believe there's a screen addiction piece when kids go to such lengths to get wifi. I've actually looked into getting a lockbox but she can still take the power cord for the modem. She's done it before. If she can't have WiFi then no one can attitude. Now I have an extra power cord locked in my room.
If there's no way to stop her from plugging in the ethernet cable from our printer into her laptop to access wifi (after resetting the modem), not sure what else to do but pay for relocation and hope for the best.
I noticed again the parental controls section of the Telus GUI has disappeared AGAIN!
Organizer
20 Messages
Thank you for your reply, suggestions and link!
Advisor
2.7K Messages
Keep in mind that relocating the modem will change the coverage of the WiFi. It may be better or worse depending on the new location relative to the layout of your house.
1 Message
Maybe don’t turn it off and let them have some freedom? If there at the age of being able to bypass wifi restrictions they should be old enough to atleast have unrestricted wifi.
Phones and computers aren’t a bad thing. They are the future and people need to learn to use them as in the near future everything will be on them and many good job opportunities will need good computer experience. That’s just my opinion though do whatever you want.
Top Contributors
View More
Community Stats
Loading...
Total Posts
Loading...
Total Members
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
Loading...
