amam
6 years agoOrganizer
I have parental controls set up on my modem. My daughter has figured out a work around. She resets the modem to default then unplugs the printer ethernet cable and plugs it into her laptop. She gets f...
- 6 years ago
Or you could get something similar to a Meraki, which although intended for business, is cloud managed and only works when it connects to the cloud (and it downloads the settings). If you hit reset on a Meraki, it will just get the settings that were in previously....
BillTelusCust
6 years agoRockstar
- amam6 years agoOrganizerI'm afraid you're right. I just may have to pay for modem to be relocated. Was hoping for other options first.
I read about disabling the ethernet connection on her laptop so I tried it but it did nothing.
I've heard of meraki but I'm not that tech savvy and my friend who has it has issues with it competing with her wifi.
Yes, I know other parents with similar issues.
Thank you! - giantbrownguy6 years agoRockstar
The other option would be to downgrade her computer account to a standard user and yourself as an administrator, then limit the settings she can control. Depending on if she's using a Mac or PC, there are different types of parental controls available.
Windows 10: https://www.howtogeek.com/666985/how-to-use-parental-controls-in-windows-10/
- amam6 years agoOrganizerThank you for your reply. My kids do NOT have admin rights. That would not be good! I'll have to test out microsoft family again but they found loopholes in that before. Same with qustodio and k9. Thanks for the links.
