amam
5 years agoOrganizer
I have parental controls set up on my modem. My daughter has figured out a work around. She resets the modem to default then unplugs the printer ethernet cable and plugs it into her laptop. She gets f...
- 5 years ago
Or you could get something similar to a Meraki, which although intended for business, is cloud managed and only works when it connects to the cloud (and it downloads the settings). If you hit reset on a Meraki, it will just get the settings that were in previously....
Related Content
New Optik Andriod tv box - Need Fast forward/Rewind & skip ahead on guide….
When watching a pvr’d program I use to be able to fast forward / rewind at 1,2,3,4 speeds. Now I can only skip 30 sec or go back by 10 Sec. I can also hold down the “wheel” and it fast forwards/rewin...Solved5.8KViews2Comments
