amam
5 years agoOrganizer
I have parental controls set up on my modem. My daughter has figured out a work around. She resets the modem to default then unplugs the printer ethernet cable and plugs it into her laptop. She gets f...
- 5 years ago
Or you could get something similar to a Meraki, which although intended for business, is cloud managed and only works when it connects to the cloud (and it downloads the settings). If you hit reset on a Meraki, it will just get the settings that were in previously....
BillTelusCust
5 years agoRockstar
amam
I'm afraid you're right. I just may have to pay for modem to be relocated. Was hoping for other options first.
I read about disabling the ethernet connection on her laptop so I tried it but it did nothing.
I've heard of meraki but I'm not that tech savvy and my friend who has it has issues with it competing with her wifi.
Yes, I know other parents with similar issues.
Thank you!
Thank you!
Related Content
New Optik Andriod tv box - Need Fast forward/Rewind & skip ahead on guide….
When watching a pvr’d program I use to be able to fast forward / rewind at 1,2,3,4 speeds. Now I can only skip 30 sec or go back by 10 Sec. I can also hold down the “wheel” and it fast forwards/rewin...Solved5.7KViews2Comments
