01-23-2024 11:02 AM
01-31-2024 07:01 PM
01-23-2024 11:44 AM
Try going into the system settings on the TV box and enable HDMI CEC. The box is able to turn my TV on or off without the remote even pointed at it with HDMI CEC enabled.
Settings > Device Settings > Device Preferences > HDMI
01-23-2024 01:37 PM
01-23-2024 12:51 PM
You could try unpairing it from the TV and make sure that the TV has HDMI CEC off, and that you have clear line of sight from remote to TV.
Here are some steps if you'd like to try this method:
If you would no longer like your TELUS Remote to control your TV’s volume and power, you can unpair your remote.
01-23-2024 01:37 PM
01-27-2024 01:35 AM
I ran into similar issue with another vendor. There is/was more than one TV in a brand that has different on/off. setup was also different than here.
Did the setup recognise your TV brand and give you an option to ignore first choice and try another. I cannot test that since it found my TV and all works.
01-28-2024 03:10 PM
01-29-2024 11:47 AM
No, I was wondering if it asked you if setup worked and offer a second chance to setup. Again since mine worked first time I cannot check if it offers an alternate menu if suggested one does not work.
01-29-2024 11:50 AM
01-29-2024 12:36 PM
Hi @gianadawn
What brand of TV do you have? I can provide instructions on manual pairing and codes if you can share the TV brand.
01-29-2024 03:26 PM
Awesome thank you so much. It is an RCA Smart TV Virtuoso. But not a Roku.
01-29-2024 03:39 PM
1. Press and hold both the input and OK buttons on your remote for 3 seconds. The green LED should stay on.
2. Enter the first code using the number pad. The green LED will blink twice and then go off.
3. Test the mute or volume up/down button. If these work, you're done.
4. If they don't work, repeat steps 1-3 for subsequent codes.
179
138
192
213
212
170
139
105
104
092
059
036
035
018
017
011
009
325
01-31-2024 07:01 PM
01-31-2024 07:02 PM
03-21-2024 07:01 PM
Is there a full list of codes for other tvs?
03-22-2024 09:56 AM
There is, but it's extensive. Looking for a particular brand?
03-22-2024 06:24 PM
I'm trying to get my panasonic tvs to be programmed properly so it would turn on and off with the new remote. TIA
03-22-2024 06:36 PM
Hi @Selman - you can try 158, 166, 168, 250, 340, 169, 063 or 216 for Panasonic TVs.
April
April - last edited April
Give these a go:
061
034
009
017
138
106
050
137
022
036
035
059
068
328
317
235
164
162
157
