Guide issues
Reichert2011
Is there a way to either stop the info from changing or at least slow it down when I am in the guide mode. I select a show and try and read the info and within a few seconds it jumps to the next screen, what a pain.
3 REPLIES 3
El-Eric
Moderator
Moderator
Hi @Reichert2011 I don't believe that there is a way to slow down the screen but I will investigate and get back to you
Edit: I was not able to find a way to slow down or pause the menu but I will pass the feedback along!
KHR
TELUS Team Member
TELUS Team Member
@Reichert2011
What device are you using? Once the guide loads, it should not move and information shouldn't change unless you are pressing buttons on your remote or scrolling.
I am using an older system, not the new android junk. so when I scroll through the guide, info pops up, but the info changes 2 or 3 times and it cycles though,
