08-20-2020 11:28 AM
Hi there. I am trying to set up a wireless TV box and I am not able to pair it with my T3200M modem/router due to a weak WiFi signal.
I was wondering if it's possible to pair a wireless TV box with a Telus WiFi booster that is a few feet away from the TV wireless box. I tried to enable WPS on the WiFi booster but the tv box still fails to pair. Thanks
08-20-2020 02:53 PM
Do you mean the Telus Boost devices? You cannot connect your TV set-top box to those. If you can run Ethernet to the TV, that would be one option, or if you can run Ethernet NEAR the TV, there is an extender available to provide a suitable signal.
08-20-2020 02:53 PM
08-20-2020 05:33 PM
Yes, I meant the Telus boost devices. Thank you for your reply. I managed to connect the TV wireless box via Ethernet eventually
