02-05-2024 10:18 AM
Hi all,
Yesterday I upgraded my Internet from Telus 75 to PureFibre Gigabit. I was noticing that I was only getting/maxing out at 100mbps through the T3200M (ethernet and wireless).
That's when I went down to the basement where my ONT was and connected an ethernet cable directly to it and got the Gigabit speeds. I noticed that the ethernet bridge between my T3200M and the Telus ONT has been substituted by, to me, what seems like an ethernet to DSL adapter? This would make sense why I am maxing out at 100mbps when connected to the T3200M.
I would assume I would need a technician to fix this?
February
@Anonymous wrote:Yes your home phone line will not need to be changed , it is ok as it is from the ont to the ethernet , adsl adapter.
@jjdinks If you are unable to bypass that adapter and get an ethernet cable pulled through and connected to where the T3200 is, please call Telus. If they installed that adapter and it's limiting your speed, they will need to correct it. If there is a coax jack near where the T3200 is located, they may even be able to put a MoCA adapter where the ONT is located and use coax to get the signal to the T3200.
February
Which port on the T3200 is that adapter connected to? Is there another adapter at the T3200 also? How far away is the T3200 located?
February
It is connected to the ethernet WAN port on the T3200.
The T3200 is located upstairs and a little bit away from the ONT, so it is not directly underneath the ONT.
So it goes. ONT out on LAN1 via ethernet to the ethernet to DSL switch then upstairs theres a ethernet wall outlet that is connected to the T3200.
I assume it is this adapter that is making my T3200 not give Gigabit speeds.
February
D you know what the model or manufacturer of the dsl to ethernet adapter?
February
How recently was the fibre installed? If fairly recently and if you have the installers card, maybe reach out to them. If not, I'd recommend reaching out to support to get a tech out to ensure you're able to get gigabit to the T3200. I've never seen them use that type of adapter before. The big issue will be if the line leaving the adapter and going upstairs only has 2 pairs of wires in it like a regular phone cord. If it does then it's physically incapable of delivering gigabit speed. Gigabit needs all 4 wire pairs on the ethernet cable.
February
You would probably need a separate phone line from the ont modem which has a RJ11 phone jack for the phone line which telus technicians from the fibre team can help with re connecting between the T3200 m and the ont modem
Also a separate line for ethernet on data 1 or lan 1 from the ont modem to the T3200 modem which you can install yourself or you would have to ask a it company or pc or network repair technicians that install network wiring or structural cabling of ethernet , coaxial or phone lines.
February
@Anonymous No, you are incorrect. Phone service, if they have a landline, would be wired to the ONT, not the T3200. There is never any case where an RJ11 cable is connected between the ONT and the T3200.
You are also incorrect in recommending an IT company, a PC repair company, or a "network repair technician" (which isn't a real thing). None of them, for the ones that exist, would be re-wiring a residence. The only correct answer is to contact Telus and have a tech sent out to ensure a proper connection is in place between the ONT and the T3200.
February
February
February
February
Your home phone line is on a separate line, on the existing copper line.
The ethernet is on a separate line, then a ethernet cable run between the ont modem and the adsl, ethernet adapter.
February
February
February
February
Can you show a picture of ONT device ports?
Can you show a picture of the T3200M modem/ router ports?
ONT / ADSL adapter connects to your ADSL/VDSL port on your T3200M modem router
February
@Anonymous The ONT is not the issue. The tech that installed the fibre / ONT would have disconnected the DSL and phone lines. If the line was connected to the phone jacks on the T3200, there would be no internet.
