jjdinks
2 years agoFriendly Neighbour
- 2 years ago
2 years agoWhich port on the T3200 is that adapter connected to? Is there another adapter at the T3200 also? How far away is the T3200 located?
jjdinks
It is connected to the ethernet WAN port on the T3200.
The T3200 is located upstairs and a little bit away from the ONT, so it is not directly underneath the ONT.
So it goes. ONT out on LAN1 via ethernet to the ethernet to DSL switch then upstairs theres a ethernet wall outlet that is connected to the T3200.
I assume it is this adapter that is making my T3200 not give Gigabit speeds.
- Nighthawk2 years ago
How recently was the fibre installed? If fairly recently and if you have the installers card, maybe reach out to them. If not, I'd recommend reaching out to support to get a tech out to ensure you're able to get gigabit to the T3200. I've never seen them use that type of adapter before. The big issue will be if the line leaving the adapter and going upstairs only has 2 pairs of wires in it like a regular phone cord. If it does then it's physically incapable of delivering gigabit speed. Gigabit needs all 4 wire pairs on the ethernet cable.
- Anonymous2 years agoNot applicable
You would probably need a separate phone line from the ont modem which has a RJ11 phone jack for the phone line which telus technicians from the fibre team can help with re connecting between the T3200 m and the ont modem
Also a separate line for ethernet on data 1 or lan 1 from the ont modem to the T3200 modem which you can install yourself or you would have to ask a it company or pc or network repair technicians that install network wiring or structural cabling of ethernet , coaxial or phone lines.
- jjdinks2 years agoFriendly NeighbourThanks,
The fibre was first installed 2-years ago I think. It was when Telus was rolling out fibre in Edmonton.
I'm pretty sure my home phone line will be okay right? I just need to get rid of that adapter and run a straight ethernet to ethernet connection from the T3200M and ONT.
Would Telus be able to fish this ethernet to ethernet port for me?
D you know what the model or manufacturer of the dsl to ethernet adapter?
