jjdinks
2 years agoFriendly Neighbour
- 2 years ago
Anonymous
2 years agoNot applicable
Can you show a picture of ONT device ports?
Can you show a picture of the T3200M modem/ router ports?
ONT / ADSL adapter connects to your ADSL/VDSL port on your T3200M modem router
- Nighthawk2 years ago
Anonymous The ONT is not the issue. The tech that installed the fibre / ONT would have disconnected the DSL and phone lines. If the line was connected to the phone jacks on the T3200, there would be no internet.
