Not getting speed of my internet plan using ethernet
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic for Current User
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Hi @JujhaarSekhon ,
Sorry to hear your speeds are not 150 as expected. I am not the best when it comes to the fiber subject, but here are some things to add more content so others may better understand the issue.
- Click Here - To visit the basic TELUS Internet troubleshooting page
- Go to www.SpeedTest.net and complete the test & post your Upload, Download, and PING.
- If you have different Ethernet cable, try using it, and do the test again to see if you have different results.
- Are you plugged directly into the modem? or into a Ethernet port in the wall?
Click Here - To read some troubleshooting steps to try while you wait for an answer from the community.
TELUS Employee & Neighbourhood Volunteer ▪️ Found this post helpful? Let others know by clicking [❤️ Like] or [Accepted Solution].
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Hi @JujhaarSekhon ,
When you get a chance, can you please try connecting your laptop using Ethernet directly to your Modem, going to www.SpeedTest.net and sharing your upload, download, and PING results?
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Ping: 1ms
Download: 85.59 mbps
Upload: 92.70 mbps
Internet 150 pure fibre
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Hi @JujhaarSekhon ,
These speeds are usually what you would expect on Internet 75 pure fibre.
Lets try the following...
- Please double check your Internet plan on your MyTELUS account. Is it Internet 75 or 150?
- Disconnect Ethernet cable, connect to your WiFi, and place your laptop around 5 feet from the modem. Then go to www.SpeedTest.net Please share your results.
- In your network configuration, do you have a MoCA attached to your modem using Ethernet? Click Here for an image of a MoCA.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Did a speed test using wifi and the results were.
Ping: 2ms
Download: 95 mbps
Upload: 101 mbps
I had 17 active devices when I did test.
I do not have moca.
When I had my Ethernet jacks fixed the technician put a ethernet switch.
Ethernet switch model: TP-Link 5 Port Gigabit Ethernet Network Switch
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
I checked my account and I have internet 150 pure fibre.
Ping: 2ms
Download: 95 mbps
Upload: 101 mbps
I do not have moca.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Hi @JujhaarSekhon ,
Alright, so with the tests done so far, we now know the wires from the modem to your devices likely not to be an issue since you are able to achieve similar results using WiFi which narrows down what to troubleshoot.
95mbps with 17 active devices is a very good speed.
That means the remaining 16 devices are sharing the remaining speeds of 55mbps (3.4mbps/device).
For safe measure, lets try disconnecting all devices except your laptop so we have a dedicated connection to the maximum speeds.
- Test #1 - WiFi within 5 feet from the modem.
- Test #2 - Ethernet directly to the modem.
- Test #3 - Ethernet from the wall (like you initially had it)
If there are any issues, they should appear with these final tests.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
I have a dvr for cameras, tv that is connected to ethernet and cable box.
I will also do the 3 tests tomorrow
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
I will do the other tests tomorrow
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Test:1 5 feet away from modem:
using wifi with only one device using internet:
Upload: 98.4
Test:2 Ethernet directly to modem:
Upload: 94.3
Test:3 test through Ethernet jack:
Upload:92.7
I think modem is not working properly?
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Upload: 98.4
Upload: 94.3
Upload:92.7
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
@BrandonT I just had a technician come over to fix it and now I'm getting speeds of 340 download.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
@JujhaarSekhon Do you know what the tech did to fix it? It might help others who have similar issues.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
I get 1 MBPS internet speed due to being rural with a 15 minute drive to the city hall. PATHETIC Telus steals from seniors.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Possibly Xplornet would be a better fit fo you.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
@JujhaarSekhon Thanks for the info.
On the fiber side it either connects or it doesn't. It must have been a bad Ethernet cable from the ONT to the modem. Gigabit connections require all 8 wires so if one or more are bad and it can only use/detect the 4 needed for 100 mbps then that's the best it can do, which matches your symptoms prior to the fix.
