December
My Telus Connect app does not recognize that I'm on my home network, nor does it recognize my 2 boosters. I try to add the boosters but it circles back to the same problem, saying I need to be connected to my home WiFi network (which I already am - very frustrating!)
I have tried, unsuccessfully, the following steps:
All of this...to no avail. Please help! What can I do to solve this issue?
a month ago
Since you've already tried several troubleshooting steps, here are a couple more suggestions to try:
- Ensure your Wi-Fi is set to 2.4 GHz: Sometimes the app has trouble detecting the home network if it’s set to 5 GHz. Try switching your Wi-Fi to 2.4 GHz temporarily and see if it recognizes the network.
- Check your router settings: Log into your router’s settings to ensure that there are no issues with the connection or network settings that might prevent the app from recognizing your Wi-Fi network or boosters.
- Try adding boosters from the web interface: Sometimes the Telus Connect app has issues, but you might have better luck using the web portal for adding and managing your boosters.
Let us know if that helps.
a month ago
Can you please provide information/specific instructions about how to do the steps you've recommended?
a month ago
