11-27-2020 09:06 AM
11-27-2020 11:01 AM
11-27-2020 11:13 AM
Can you connect with ethernet? Even then there are times when my MacBook is assigned a new name, so there seems a re-connection issue, but it resolves quickly.
11-27-2020 11:19 AM
When you have this issue can you hit the router web page to confirm that you indeed have a WiFi connection? I find it hard to believe that the T3200M would care whether the client is a Mac or not after getting a WiFi connection. It possible the WiFi status isn't correct and you don't actually have a connection.
11-27-2020 02:19 PM
11-27-2020 05:53 PM
11-27-2020 06:03 PM
So the issue is the Mac doesn't reconnect to WiFi coming out of sleep and lies about it.
It's not clear whether it tries and can't or doesn't try at all.
11-27-2020 09:43 PM
So I bridged the T3200M to my airport extreme and changed nothing else. My computer reconnects to wifi fine when waking. It is definitely something to do with the router.
