Additional SSID on Telus arcadyan wifi hub?
Ingepenne
So how do you another SSID to this modem? I cannot seem to find a way using the admin login 192….etc
Is it possible?
Or at the very least to secure the guest wifi option?
5 REPLIES 5
dru
Community Manager
Community Manager
@Ingepenne Have you tried downloading the TELUS Connect app?
I have downloaded the connect app. It does not allow for addition of a second SSID.
TELUS_Tech_Guy
TELUS Employee
TELUS Employee
Are you talking abou a GUEST WIFI?
Above is an example of a router capable of broadcasting multiple SSIDs.
The current setup of the telus unit is setup broadcast two SSIDs - the secure primary SSID and the unsecured Guest SSID ( for which you cannot assign a password)
https://www.cisco.com/c/dam/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/im...
On my older telus modem/router I can easily to into admin and create a dedicated 5g ssid, a 2.4g specific ssid and a general or default mutliband ssid all with different names and passwords.
