07-16-2024 03:35 PM
Hey there,
I got a boost Wi-Fi setup with 1gbps speeds yet my speeds have been maxed at 93 mbps with or without ethernet connection. After searching for hours, the only lead I found was disabling the auto mesh for the router and direct connecting to the 5GHz band. I also get 94 download latency and I would be curious to fix that as well. I have made sure to switch my router band to 5GHz and made sure my channel has little to no traffic.
Computer Specs:
13th gen Intel i9-13900H
NVIDIA GeForce RTX 4050 Laptop GPU
16 gbps Ram
Windows 11 Home
07-16-2024 06:20 PM
Hi @Carer, is connecting directly to the router any better?
07-16-2024 07:45 PM
Exact same results even without the ethernet connection. I played around with the auto mesh and couldn't get it to separate the router so that I could test the 5GHz specific network but if ethernet does not work I would guess that wouldn't do much either. My ethernet cables are Cat-6 so there should be no issue with those
07-17-2024 03:25 PM
So are your issues related to Wi-Fi and wired? That is definitely an issue. We will send you a message to try to help with the situation
