Carer
1 year agoNeighbour
Boost WiFi Ethernet connection not getting 1gbps
Hey there, I got a boost Wi-Fi setup with 1gbps speeds yet my speeds have been maxed at 93 mbps with or without ethernet connection. After searching for hours, the only lead I found was disabling...
1 year agoHi Carer, is connecting directly to the router any better?
Carer
1 year agoNeighbour
Exact same results even without the ethernet connection. I played around with the auto mesh and couldn't get it to separate the router so that I could test the 5GHz specific network but if ethernet does not work I would guess that wouldn't do much either. My ethernet cables are Cat-6 so there should be no issue with those
- TELUS_Support1 year ago
So are your issues related to Wi-Fi and wired? That is definitely an issue. We will send you a message to try to help with the situation
