jujubehead
6 years agoNeighbour
Weird problem with parental controls disappearing on T3200M
I'm trying to use the parental controls on the T3200M. Looking in the "Advanced Settings" screen, the menu item on the left for parental controls was not there at all. The admin home screen s...
- 6 years ago
Hi there,
I have an update. Working with a couple resources from TELUS support management and development they have confirmed that the TELUS My Wi-Fi app is the supported replacement for the parental controls in the T3200M modem. This change is effective with the last firmware upgrade to the modem, version 31.164L.22.
Reverting to firmware 31.164L.18 or lower, through a factory reset of the modem, will restore the original Blocking/Filtering section with parental controls in the T3200M modem, however the workaround would be temporary as the modem will continue to pickup the latest firmware from TELUS and perform an automatic update. The new firmware is more secure than .18 so this is likely not a recommended solution.
The parental controls in the TELUS My Wi-Fi app have some know limitations compared to the original T3200M-based controls:
- Scheduling: Some devices cannot be paused or included in the child profiles (Ex TELUS Optik STB). TELUS Optik PVRs work fine.
- Filtering/Blocking: There is no definable web or protocol filtering, other than the generic option to filter out Adult content based on age ratings.
To filter specific apps, such as YouTube, TikTok or Pokemon. If you own an Apple device with Family Sharing setup, there is a relatively new setting called Screen Time that has proven to be an absolute life savior for our family's balancing of digital time: https://support.apple.com/en-ca/HT208982
There are similar options provided by Microsoft for Windows and Android (https://support.google.com/families/answer/7103340?hl=en), but I am less familiar with them and do not want to stray to far off thread here.
Hope this helps.
cwant
I installed the Telus My Wifi app yesterday, and the blocking/filtering controls disappeared. I wonder if these two events are related? Do others having this problem also have the My Wifi app installed?
cwant
Would love to get this stuff sorted out. With kids at home for school due to COVID, it's less the adult sites that need blocking, and more the distractions (youtube, games, Pokemon, etc.). Having some control over this would be great (whether it is with the Actiontec modem, or with the My Wifi app, don't care which, as long as it works).
- worldtel6 years agoOrganizer
Hi there,
Hope this helps.
- Spinach5 years agoNeighbour
I cannot find the parental controls in the app...could you point me in the right direction?
Thanks for sharing all your research on this. I've been super frustrated with the changes they made to the modem, blocking and filtering wasn't even great to begin with. I'm considering going to shaw over this issue.
