Variable's avatar
Variable
Friendly Neighbour
7 days ago
Solved
Is T3200M compatible with Wifi Boost 7 (v3.0)?
I currently use the Actiontec T3200M connected directly to the fibre receptacle on the wall (I live in an apartment that is pre-wired for fibre). I recently upgraded to PureFibre Gigabit. The CSR sta...
  • TELUS_Support's avatar
    4 days ago
    Hey Variable - the Boost 7 needs to be plugged into the Network Access Hub so your problems may be due to the Boost 7 being connected to the T3200
