Dashpuppy's avatar
Dashpuppy
6 years ago
Solved
Home Fiber Connection _ Ip keeps changing every few days.
Why does the lease time on the Telus Fiber connections have to be so low ? My ip address keeps changing every few days. I work from home and have multiple vpn connections for work & the phone system ...
  • Nighthawk's avatar
    6 years ago
    Check your router. It sounds like it may not be properly renewing the DHCP leases in time. Normally an IP change is rather infrequent, at least using the Telus gateway.
