What IR works with the Telus 4k Cable box?
BrendaLSmith
We recently bought a 75" TV, and the cable box can be mounted behind it but the cable remote won't work, as the signal won't bounce off the wall or ceilings as the tv is so big.
What IR can I install that works with a Telus 4k box, model # UIW4001 ?
Thank you for your help.
IslandGuy
Coach
This works with the 4k pvr and every optk box iv'e tried it on.. stereo extension cables for receiver.. mono for transmitter
11 REPLIES 11
WestCoasterBC
If you use the search query on that topic. There  are several posts that can lead you in the right direction. I believe there are a few that posted what worked for them.
I couldn't find a specific IR. Can you recommend one?
FuzzyLogic
I believe the box supports Bluetooth. I can't confirm as I have a different STB.
More info here:
DS_UIW4001.indd (go2mhz.com)
Might be worth a try.
It does support Bluetooth, but I need an IR....can you recommend one that is compatible?
IR requires 'line of sight' so you will need to put the box somewhere that is unobstructed for this to work.
Normally there is a few inch gap for the TV stand that should be sufficient to get the IR signal to the box.
Using a different IR remote is unlikely to make any difference. Bluetooth doesn't have the 'line of sight' requirement.
Sorry....I should have said an IR 'EYE'...I need to buy an infrare red 'eye' that attaches to the box, and has an eye, which is a small 'bud', that attaches to the edge of the bottom of the tv.
Do you know of a brand that works with the Telus 4k box ?
As far as I know there is no way to connect an external IR receiver to the Telus 4K box. You will need to find a location for the box that has unobstructed line of sight. Possibly get a longer HDMI cable and put the box somewhere away from the TV?
Balls.....my STB's are  stuffed behind 4 TV's hanging on the wall and work fine....hence " no line of sight".
What about mounting a small mirror just below the TV to transfer the IR signal to the hidden set-top box?
IslandGuy
Coach
IslandGuy
Coach
