Audio receiver control
RobG3987
Advocate
I've gone through the steps to successfully link my brand of audio receiver to the OPTV remote and the volume controls works fine.
However when I press the power button on the remote (expecting all my devices to turn off) only the TV and Telus portal turn off and the audio receiver remains on.
Is this normal or do I not have the correct code selected to provide this function?
It is a Pioneer receiver and I used the process of holding down the Mute and 4 (for Pioneer), then the right side of the pad, OK once I verified the volume worked.
My previous remote from Shaw (which I still have to use to turn the power on/off now) did function properly to turn the TV and audio receiver on/off together.
2 REPLIES 2
WestCoasterBC
The newest one that comes with the new OPTIK TV equipment. On the website it's called the "Telus TV Remote". The other 3 listed are Slimline 2, Slimline, and Classic which it is none of those.
