Manual remote programming link broken
RobG3987
Ambassador
In the instructions posted for programming the Optik remote for control of audio receivers on your site , there is a link to manual programming instructions.
But the link is broken and results in error 500.
Can the instructions be reposted.
https://docs.google.com/viewerng/viewer?url=https:https://assets.ctfassets.net/9mt4r6ro1ay9/58g7Qxr3...
FuzzyLogic
Try this link:
TELUS TV Codes (ctfassets.net)
4 REPLIES 4
WestCoasterBC
Don’t relying on google search. Use the remote programming instructions located Here.
Yah,, I did. That's EXACTLY the path I followed which resulted in the error I reported.
Try doing this for me then:
Select Telus TV remote
Select pairing for AV receivers
Scroll all the way down to the Manual Code Entry and select the link for the "pair your remote"
And tell me if it works for YOU.
FuzzyLogic
Try this link:
Well that one works! Thank you!
From the first post,,Strangely enough, if I try from my mobile I get the error,, on all 4 different browsers (yes I tried clearing cache and history, etc)
Tried from my laptop,, it worked.
This link works from my mobile and laptop. TYVM
Type a product name
