unlocked phone not working
Reply
Highlighted
Resident
A few months ago i called telus and went through the process of unlocking my phone. I am finally trying to use another SIM outside Canada and it says it’s invalid. Did telus not properly unlock it and if so how do I reach telus if i’m on airplane mode to fix this? Their 416 # doesn’t work on whatsapp.
Accepted Solutions
Highlighted
Most Helpful
Ambassador
A Skype voice call to the telus mobility  1-866-558-2273 should work .
All Replies
Highlighted
Most Helpful
Ambassador
Highlighted
Ambassador
What is the exact error message
Highlighted
Rockstar
Is it an iPhone?  If so, that message can appear sometimes when the device needs to be updated, which you can update over WiFi first, then reboot the device with the SIM in and see if that message goes away.
