samsung galaxy s3 overheating
Reply
Highlighted
Resident
The last two nights I wake up in the morning and my phone is extremely hot. it wasnt charging or plugged into anything else.
Accepted Solutions
Highlighted
Most Helpful
Ambassador
You might have some background running apps or low data reception causing your phone to work harder. It could also be a faulty battery. Try removing your battery and test again. If the issue persist, you could try a factory reset under Settings or bring it to any store. They can send it out for repair or exchange your battery if you are under the 1 year manufacturer warranty
All Replies
Highlighted
CPU Alum
CPU Alum
What happens if you reboot the phone?
What happens if you put the phone in airplane mode while sleeping?
Highlighted
Most Helpful
Ambassador
