Will this phone work on Telus network?
redmagic5g
I purchased a Red Magic 5G phone and was wondering if it will work on the Telus Network.
The Specs are as follows for Networks
Network*
SIM: dual SIM
SA+NSA: compatible with both standalone and non-standalone modes  
5G: NR n41/n78
2G+3G+4G:
GSM 2/3/5/8
WCDMA B1/2/4/5/8/19
CDMA/EVDO BC0/BC1
TD-LTE B34/B38/39/40/41
FDD-LTE B1/B2/B3/B4/B5/B7/B8/B20/B12/B17/B18/B19/B26
Hero
I think Telus 5G uses N66 so you will only be able to use LTE.
2 REPLIES 2
You can check here for compatibility information.
Hero
