dru
+26 more
Community Manager
2K Messages
Will my phone work on the TELUS network?
You’ve purchased a non-TELUS device and you’re likely wondering if it will work on the TELUS network. To confirm compatibility, your device:
1) should be listed as "compatible" via the IMEI checker*
2) is subsidy unlocked. If unsure, contact the originating carrier and/or manufacturer.
3) supports TELUS frequencies. TELUS deploys HSPA: 850/1900 MHz (UMTS); LTE: 700/850/1700 uplink (AWS)/2100 downlink/1900 MHz
4) is not reported lost or stolen. You can check the device IMEI against the National IMEI blacklist*
*Your IMEI is generally printed on the side of the original box or on a white sticker on the device under the battery. IMEI can also be found by entering *#06# into your phone app.
Next, review this following guide on how to program an access point into your phone for cellular data services.
To find out which SIM card is suitable for your device, please contact the manufacturer or contact us.
Support Article
Updated
44.7K
2
0
Top Contributors
View MoreTELUS_Support
+22 more
Community Manager
8.1K Messages
FuzzyLogic
+25 more
1.8K Messages
Coach
30 Messages
Community Stats
Total Posts
Total Members
