WiFi Boost and Ethernet
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic for Current User
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Hi everyone,
I've just set up my two Wifi Boost sets, and I'm wondering whether the original one needs to stay connected to the router through the ethernet cable, or whether I can remove it and put it the booster in a different room (the second one is already where I want it to be)? Seems like it's kind of a waste to keep it next to the router, when the room with the router doesn't need any additional boosting. On the other hand, I don't want to monkey around with it anymore since it took a lot longer to set up than it should have.
Grateful for any input! Thanks!
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
All Replies
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Hi xray, thanks for your reply. The boosters came in a pack of 2, so by original I mean the first one of the pair, which is connected to the router by the ethernet cable. I didn't have any boosters before this, but from what I'm reading, it looks like I'll have to get at least one more.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
The T3200M router requires an Ethernet connection to the first Boost. The newer Arcadian unit does not, once the Boost units are set up, it manages the mesh from the router itself, allowing placement of Boost units away from the router location.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Thanks again, xray. How do I disable the wifi on the router? Will that change the name or the strength of my network?
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Thanks, NFtoBC! How do I know if this is an Arcadian router? If it helps, it was set up last August.
Grateful for the input. 🙂
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
@Yatsukin Look here to identify your router.
https://www.telus.com/en/ab/support/interstitial/troubleshoot-boost-wifi-actiontec-t3200m
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
@NFtoBC Good to know. I have the T3200M and don't use the Boost so I'm just going by the online info which is a bit vague when it comes to the Arcadyan. Does the Arcadyan (WiFi Hub) become one node in the mesh or does it disable it's own WiFi automatically when the boost is added?
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
It becomes node 0 in your mesh. AFAIK Wireless Optik set-top boxes need to connect to node 0.
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
Looks like the Arcadyan router is white. Mine's black, so going by the link xray showed, I better just keep the first booster connected to the router.
Oh well!
- Mark as New
- Bookmark
- Subscribe
- Link to Post
- Email to a Friend
How great that you posted this question. In a magical universe, your question would be the first one to be answered - on the Telus box, on the Telus site. Your question - do you need to keep the #1 booster connected by Ethernet - is the very first question I had (I'm an engineer). That said, I do not consider the question "Answered". 1) First of all, your Wifi router and Telus Booster #1 should not experience any interference if you put them on separate Wifi channels. 2) It's clear as mud, as to what equipment uses your original Wifi router as part of the mesh, and which setup doesn't. Are there most than one version of Boosters? Which Telus routers want it one way or the other? I find the situation hilarious that what is for me the #1 most essential information, is exactly what Telus is doing "Information Hiding" on us with. Summary: question not answered.
