10-12-2020 04:57 PM
I logged into my Wi-Fi hub from both the app and direct to the modem. The speed test function is no longer available. Does anyone know where this went to? For a week I was only getting about 500mbps on the 940 plan. Now I can't really test it direct to the modem. Any thoughts or ideas?
10-13-2020 10:51 PM
if you are running thru the Hub my suggestion and what I do is I use the competitions speed tests dont use the same as who your providers use they can be manipulated to show you what you want to see not what actually is...
10-13-2020 11:43 PM
I usually run directly through the hub for consistency. For about a week I was only getting 50% of my download to the hub. Eliminating all other equipment/connections helps to narrow where the problem is originating. Since that service call I no longer have access to run speed tests to the router directly through the My Wi-Fi App. The option is completely gone.
