11-26-2020 11:22 PM
Hi
I am running fiber to multiple points in the house due to multiple reasons. I want to know what style of connector should be at the TP and the ONT to make sure the service tech does not have issues connecting.
Also I assume TELUS want single mode cable all the way or should the patch be Multi mode?
Thanks
11-27-2020 12:11 AM
Telus will attach their connectors to the fibre. Fibre is only used to the ONT; all other connections are ethernet cable.
11-27-2020 11:08 AM
11-27-2020 01:53 PM
It's really not hard and maybe needs $30 in tools and ports. Do it yourself.
Telus moving wiring and adding is costly. I had them move my ONT from the living room to the garage and it cost me $450 (just because my daughter was small at the time and constantly trying to grab the wires...otherwise I would have mounted it to the wall - they left a few feet of cable lying around during the original install).
