Does Fiber Internet SmartHome Wifi Router/Modem Cable Connection still work in Bridge Mode?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-07-2020 11:59 PM
I have a fibre connection and a TELUS Wi-Fi Hub modem/router.
If I put the modem into bridge mode, will the coax cable outputs still work?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2020 01:17 AM
Bridging should only affect LAN 1. Try it. Worst case, you can return it to the default setting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2020 12:48 PM
Thanks @NFtoBC
Is there a manual somewhere for the modem/router? I'm a technical kind of guy and would love to read the actual documentation instead of experimenting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-08-2020 03:17 PM
I haven't come across a manual for the wifi hub yet. The manufacturer doesn't offer one either.
If you find a post useful, please give the author a "Kudo" or mark as an accepted solution if it solves your trouble. 🙂
