Delay Connecting To Internet - Wired Connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
May
I recently had Fibre installed in my home and signed up for a plan with Telus. Everything is great except my PC connected to the router takes about 30 seconds to achieve a connection. I can only assume it's because the router has to communicate with the gateway to assign the PC an IP address. I tried setting a static IP in both the gateway and within Windows for my network adapter but neither fixed the issue. Is this just impossible and something I have to live with or am I missing something? Google doesn't seem to know and I couldn't find a topic on here of someone having a similar issue.
I hope to hear from someone soon as this is driving me nuts! Haha! Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
You mention a gateway and a router which is a bit confusing to me. You should have a router and an ONT. The router is where you would be adjusting the DHCP settings but you are saying you did it on the gateway.
Maybe you can provide some information to clarify your situation.
- Model numbers of the TELUS supplied devices
- How is your PC connect to the network, Ethernet or WiFi?
- Do you have other devices connected the same way and do they have the same issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
So what Telus refers to as a Gateway is the Technicolor NH20T. The router is a R02. Does this help piece things together?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
This post by @FuzzyLogic seems to describe the same issue you are facing:
"I also use the ethernet ports on the AP and they work fine but seem to 'hibernate' if not used for a while and take a bit of time (~30 seconds) to wake when the device connected to them is turned on."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
May
